08-05-2017 01:56 PM - edited 01-05-2022 02:35 AM
06-04-2018 09:34 PM
To be fair when I was a newbie I think my first post was to an old thread too
06-04-2018 08:49 PM
@MacMe wrote:
@Carmenwile13 wrote:It should Work just fine. Call customer service at bell and asked to get your phone unlocked. they will walk you through it. Dont forget to check if your phone is compatible with public mobil service. You will need your MEI number that you will retrieve from bell.
This was a thread from August 2017 🙂
@jp2 yep, it never ends......... (reference, for anyone not sure what I'm talking about)
06-04-2018 08:13 PM - edited 06-04-2018 08:14 PM
06-04-2018 07:57 PM
08-05-2017 02:40 PM
@Ottawatech Check out kijiji. For android, there are several people who would unlock it for $10 max.
For iphone $30 max.
08-05-2017 02:34 PM
08-05-2017 02:29 PM
08-05-2017 02:28 PM
08-05-2017 02:22 PM
08-05-2017 02:22 PM
If you can't wait, you can get android unlock for about $10, iPhone with turbo sim for $10 to $30.
08-05-2017 02:00 PM
08-05-2017 01:59 PM - edited 08-05-2017 02:00 PM
u need to get the phone unlocked. if its an android check out ebay.
if iphone best to get bell to unlock if usually $50. else wait till jan when carriers will need to unlock fro free.
Also there was a member offering unlock codes for free for samsung phones i believe.
08-05-2017 01:58 PM
No, it will not work on Public Mobile. You will need to unlock it in order to use it on Public Mobile.
