just Unconditional call forwarding works, others say: connection problem or invalid MMI code
Farzinf
Hi,
I can only set unconditional call forwarding using *21*number#,
I need to set Not Reachable call forwarding using *62*number#.
when I dial it it says;
connection problem or invalid MMI code.
My Volte is enabled and I'm using Galaxy S22 Ultra.
Any suggestion?
Thanks
DennyCrane
As far as I know conditional call forwarding is still broken.
Yummy
If VoLTE works on your phone then using voice mail menu you should be able to set up other voice mail options.
Maybe those codes do not work with PM.
@Farzinf
Voice mail options
Voicemail FAQ | Public Mobile
