12-03-2023
03:09 PM
12-03-2023
04:41 PM
computergeek541
Conditional forwarding stopped working January'23, but as I didn't have mobile service I couldn't reactivate it. I just tried to activate it again but the unconditional options do not work. . Message: Call forwarding connection problem or invalid MMI code.(0)
Can someone help me, please?
Maggie
01-13-2024 08:37 PM
I have it working on my Pixel 7 (VoLTE on PM).
Steps:
I successfully enabled it in the fall and it worked flawlessly until a few days ago. Went through the steps again, and it works properly as before.
HTH
12-18-2023 07:08 AM
Just dealt with this - Was using YouMail till it broke in the spring. Never bothered to start looking into it till the past month or so. I kept getting the mmi error with my 4g plan. Sunday I renewed onto a 5g plan and it works now.
I tried going through the customer agent - with the generic responses that I had already found in the forums and help pages. Tried to change phone to 3g, 2g, 4g, volte, etc.
If anybody else can confirm that they are on a 4g plan vs a 5g plan and if it works when switching to a 5g plan. Am using a Ulefone as well - not generally a 'supported' device.
12-04-2023 09:58 PM
Thanks for trying, but I use an android phone.
12-03-2023 10:44 PM
I found this on Apple website, if you have a iPhone with iOS 17
If conditional call forwarding isn't working as expected
If conditional call forwarding that you set up with your carrier isn't working as expected or you don't see the option to decline an incoming call, turn off Live Voicemail to continue using conditional call forwarding:
Open the Settings app, then tap Phone.
Tap Live Voicemail.
Turn Live Voicemail off.
12-03-2023 04:06 PM
Thank you, but it doesn't work in either case.
12-03-2023 03:43 PM
It might work if your have VoLTE activated otherwise it does not work.
12-03-2023 03:14 PM
@MaggieSh Yes it been broken around here for sometime now it seems .
