07-30-2024
01:18 PM
07-30-2024
04:50 PM
computergeek541
Call forward *004* code returns an error and forwarding fails. Specifically I am trying to set the voice mail answer time to 30 secs.
*#61# -> Shows all call forwarding disabled.
I would like to set a voice mail answer time of 30 seconds via this command from your help pages:
Variable Redirects incoming calls after the call has not been answered for a specified period of time -> Dial * 004 * + ten-digit phone number** + (number of seconds)# + SEND
However I get an error :
Error performing request
Unknown Error
Setting Activation Failed
Voice Call Forwarding
All Conditional Calls
Actually all call forwarding items return an error.
What have I missed?
Thanks
07-31-2024 10:38 AM - edited 07-31-2024 10:40 AM
Thank you for your suggestions:
1) checked and confirmed
2) ticket submitted
3) multiple attempts across multiple days
4) checked
5) ticket submitted
currently waiting on the ticket response
thank you
07-31-2024 08:27 AM
07-31-2024 05:32 AM
"you can just dial ##004# to reset all forwarding to default, which is the voicemail"
Thanks for the insight.
07-30-2024 01:50 PM
HI @Mark_Lee
it is the default one, it will send to voicemail after 6 rings
07-30-2024 01:47 PM
So how do I extend the ring time. People call and say they get 3 or 4 rings, of which I hear the last, and the I get dead air when I pickup.
Really frustrating.
I would like to get as many rings as possible before the system does… whatever the heck it is doing. 😞
07-30-2024 01:41 PM
hi @Mark_Lee
you have voicemail, and voicemail works
you don't have to do anything to have the calls forward to voicemail if not received
07-30-2024 01:39 PM
Thanks for the replay. And that sucks. Wish I had known. Makes it hard to job hunt when you don’t have voice mail.
I’ll need to seriously discuss moving back to one of the big guys. 😞
07-30-2024 01:36 PM
Thanks for the reply. I did finally get a ticket submitted… after 2 hrs of click, click, click.
It is true you get what you pay for and I am not paying for real people help, just chat bot help. 😞
07-30-2024 01:22 PM
HI @Mark_Lee
conditional forwardings fail for many of us since VoLTE was introduced. Some said PM CS agent can help to fix, but I am not sure
you can submit a ticket and ask them to check and hopefully get that resolved
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
07-30-2024 01:21 PM
@Mark_Lee
Right now call forwarding isn't working. Public Mobile is aware of this. As of right now there is no fix for it. Unfortunately during time you will not be able to forward your calls. Try using unconditional call forwarding.
