a week ago
- last edited
a week ago
I'm also having issues with disabling call forwarding. I tried #21# or ##21# or ##004# . I have turned off and on the iphone.
Thursday
How do I find the voice and data screen on i-phone 14 pro?
a week ago
OK, I figured out how to do it! On iPhone. First, you have to switch your cellular to 3G. After that, you can change the call forwarding on and off like you want.
a week ago
What phone do you have?
Check your dialer settings menu and see if there is a Call Forwarding menu, try using that to disable it
Some dialer settings menu (like OneUI 9) no longer offers that, or if that setting change does not help, ask PM Customer Support to assist further. Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account. Select Start a Chat to begin:
https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/SMS alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
a week ago
i got the same error message
