10-10-2025
06:41 PM
10-10-2025
11:49 PM
computergeek541
I turned on call forwarding temporarily to a secondary number. Now it won't deactivate.
All to no avail. My calls still go to my secondary number.
Is this something that needs to be fixed on the network end? Perhaps they can toggle on and off my call forwarding?
edited by computergeek541: changed category labels as this discussion isn't related to Community
10-10-2025 08:23 PM
ask PM to help to clear all the forwarding. They cannot help to enable forward, but they can help to cancel forwarding. Since there is problem to open preferred Chatbot ticket. So, you will need to message them here:
10-10-2025 08:18 PM
hi @dbi987
I don't think ##002# is the right one
should be #004# for disabling all. If that does not work, try dialing them individually: #61#, #62#, and #67#
or check this page for further help: https://www.publicmobile.ca/en/get-help/articles/call-forwarding
10-10-2025 08:11 PM
Which settings are you referring to? Call forwarding comes with our plans so I don’t see it as an add on that I can remove and re-add.
10-10-2025 08:11 PM
I received the attached error.
10-10-2025 06:44 PM
To reset all call forwarding on Public Mobile, dial ##004#
10-10-2025 06:43 PM
Did you try to go through PM settings?
