6 hours ago
Why did you cut my services off after I paid 15 dollars for a week of usa roaming
5 hours ago
5 hours ago
@Pggaron which add-on did you buy, was it the US Roaming - Talk text (15-day) add-on?
5 hours ago
Maybe you used up the data already ? Login to My Account or on the app and check what it says about the US roaming
if you still have the US roaming, could be just a network connection. Try connect to T-Mobile and AT&T manually. Could be one of the networks not working well
if you need, ask PM to check, Just open ticket with them using the Orange Chatbot icon on lower right, start typing Submit ticket, choose Contact Us and then follow the screen to login and submit ticket
