is it possible to get advantage of 12MOIS2GO after activate new sim ?
mouradzoghbi
I have just activated my new sim but after finish i discover the offer 12MOIS2GO :
For a limited time, get an additional 2GB of data every month for free* for 12 months on plans $25/mo+, exclusively online. Switch to Public Mobile.
my forfait is 37,50 $ pour 2 Go à la vitesse 4G37,50 $ so normally i have this advantage with code 12MOIS2GO
mouradzoghbi
how i m a new user
HI @mouradzoghbi   if you have just activated and forgot to add the code, YES, likely CS agent can help.  Just open a ticket with them.
@mouradzoghbi
You will need to contact customer serve agent.  They are usually understanding about these situations.
You will need to contact customer service agent (CSA):
Submit a ticket for CSA help.
https://www.publicmobile.ca/en/on/chatbot
Follow the prompts to submit ticket.
CSA may ask a few questions to verify account ownership and then should be able to help you. Response times can take a few hours.  Check your private message inbox (envelope in upper right corner of website).
hairbag1
So when did you actually activate your new account ?
mouradzoghbi
how can i do to have the option +2GO ?
