incoming text counting against my text limit
HKim
Hello. My plan allows unlimited incoming texts/month and 50 outgoing texts/month. However, incoming texts are being added to my # texts used and reducing my remaining text messages.  I have an iphone4 and am not using data, wifi or imessage. Please help!
9 REPLIES 9
HKim
Thank you. This is very helpful. I will try it!
Hi @HKim
I would submit a ticket to the moderators and explain the matter to them for an explanation.
To contact a moderator, there are 2 methods:
  1. Use the ticketing system - faster response time. Click on the bubble in the lower right corner and request moderator assistance, then select account-related issue, then select you need a human now.  Follow the prompts to submit a ticket.
  2. Send a private message to the moderator through the following link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
HKim
My existing plan is fine if it would correctly count the texts.
HKim
Thank you. No, my phone is not sending read receipts. I have checked with someone with whom I frequently exchange texts.
That's exactly what I had thought, @Anonymous .
@HKim , could your texting app be set to reply with read receipts, or other kind of confirmation, which may be being sent to folks texting you?
I'd ask someone if they're getting that back from you when they send you a text.
I did a brief search but still wonder...do iphone imessage read receipts or any delivered indication use an outbound SMS internally therefore getting counted? I don't have an iphone so I can't test with the $10 plan.
@LurganIeUk wrote:
Can you afford to consider the $15 plan?
@LurganIeUk  @Triguy
This wouldn't make a difference as the $10 plan also includes unlimited incoming text messages.
@HKim
Since incoming messages are reducing the amount of text messages remaining in the counter out of the 50, there is an account problem. You'll need to open a ticket to the moderators by going to: https://publicmobile.ca/chatbot
Triguy
If you are able to pay for a higher cost plan $15 or more that has unlimited texts.  Another option would to use Wi-Fi apps like Textnow or WhatsApp.
LurganIeUk
