12-26-2017 11:40 PM - edited 01-04-2022 03:11 PM
12-27-2017 01:17 AM
@eileendowner, on the current plans, 30 day Canadawide is $5 more than Province wide, and on 90 day it’s $15.
Not knowing how many minutes of calling outside of your province you do, there are LD addon available that will not expire until fully used, rather than the Canadawide plan.
minutes per average 3 month period, it would be cheaper to renew the addon when required, than switching to Canada wide. If you use more, then yes switch.
12-27-2017 12:53 AM
@eileendowner, it is not about messing it up trying to fix the error. The problem is that you can only future date a change without incurring financial penalty for the error. The moderator team may be able to help make the change now without the pain on the wallet.
12-27-2017 12:10 AM
You will have to message the @CS_Agent and give them your acct # and phone # and let them know what changes you wanna do. You can always do it yourself on self serve but sometimes you can mess up something so i suggest you to message the moderators if you dont wanna mess anything up.
