how to transfer credit balance
JWY
I have a credit balance of one account, that will expire in a month.  How can I transfer it to another account that I have on Public Mobile ?
darlicious
@JWY
Why is it going to expire? Are you abandoning the account? If so then private message me....
@JWY
Sorry, you can’t transfer credits to another account. If it is not too late, you can remove the CC or AutoPay so you won’t be charge for next month.
dabr
@JWY   You mean your account will be closed in a month because you're porting out or just don't need it anymore?
PM is prepaid and will usually not do fund transfers although I do think, IIRC, that kind of request has occasionally been accommodated and would depend upon the circumstances and where the credit balance is from.
You can always submit a ticket to customer support via chatbot bottom right of screen and see what the response is.  Second option is to send a private message to CS_Agent via the envelope icon top right.  Good luck.
@JWY   Sorry,.  Amount cannot be transferred between accounts.
You are going to cancel service with PM? Your amount will always stay in your account for use in the next renewal
