2 hours ago
2 hours ago
support reached back, i think its doable. Great support from pm as always
2 hours ago
You have to be in PM service area, be active and being able to receive SMS from PM.
2 hours ago
You have 90 minutes to reply to the text so porting will be cancelled.
If you are in USA, you can purchase a Roaming Add-on and reply to the text when a CS_Agent restarts the porting process for you otherwise you will need to return to Canada and restart the porting process when you return.
2 hours ago
@Jakezxcxz Contact Public Mobile customer service and ask them to manually approve the port. Open a ticket at the chat icon bottom right of this page.
2 hours ago
basically you cannot unless you have a friend to help you. But that still involves getting another sim card for your friend in Canada so he can manage the port authorization text for you
