New subscriber issue
AndrewL1
Hello, I subscribed yesterday to public mobile from Bell. I did everything I thought I was supposed to, but I’ve got no data, no phone usage.  I clicked the button to transfer my number from bell, and clicked the email from bell to say yes to the transfer. The E sim installation seemed fine. It says Public Mobile as my carrier on the top of my phone, however it says SOS only.  I went to settings and everything looks fine there. Please help
2 REPLIES 2
@AndrewL1
Confirmation email from Bell???
It should be a text from Bell!
Porting is done through the PM app and texting.
slusagm
did you remove your old Bell sim card or disable the Bell eSIM?
try Reboot phone and Reset network settings
if you still have no data, ask PM to check and help.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
