07-06-2024 02:05 PM
looking how to get in touch with a real person ( phone number ) at public mobile as unable to figure out what they say to do to unsubscribe .
07-06-2024 10:20 PM
@brickown As long as you don't leave the port until the last minute you should be fine. Get it started a few days before renewal date to give you a buffer just in case.
07-06-2024 07:51 PM
Thanks so much for that info .. appreciate your input .. site says account is good till August so I think I am in the clear. However knowing my luck some kind of screw up will no doubt happen.
07-06-2024 04:30 PM
@brickown I guess they don't want people to change providers.
If you're changing providers your Public Mobile account must be active. You contact the new carrier and they arrange the transfer of your number and then your PM account is automatically closed. So make sure you port out before your next renewal date.
07-06-2024 02:21 PM
That worked !!!!! /thanks so much Hairbag 1 ! appreciated the page view .....nice and clear what to look for . Thanks too to hTideGnow for trying to assist .
07-06-2024 02:14 PM
Hi , tried that My Account, Payment, however clicking on Payment does not bring up Manage Subscription so unable to disable "suscribed" it just shows a bunch of other subscription payment options. Also no where on any page does it give info on how to unsubscribe from my phone plan. Really is not user friendly . I guess they don't want people to change providers.
07-06-2024 02:11 PM
07-06-2024 02:07 PM
hi @brickown
they are all real person here.
but to unsubscribe, you just need to disable autopay. Login My Account, Payment, Manage Subscription and disable "Subscribed" there. With that, PM won't renew your plan after your current cycle
or you can also port your number out while your account still active
if you need to contact support agent, they are all real person, you just need to submit ticket
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
