Activation
David1976
I subscibed to Public Mobile about 2 hours ago. Calling and texting works but no data but I paid for 75GB. Any ideas?
2 REPLIES 2
@David1976  Try rebooting the phone or reset network settings see if that helps
also check your APN setting is
  • APN: sp.mb.com
slusagm
did you use Change Now option? only that will change plan immediately
reboot the phone once More and make sure you didn't have data limit set on your phone
