04-17-2024 01:11 PM
10-24-2024 09:37 AM
@Wayworn wrote:It seems that my posts are being rejected and most by Oracles - This results in loosing bravos and solutions. Maybe someone should explain to me the reason. Cut and pasting just one page of my rejected post - The list is a long 28 page list .
Please refer below to @hTideGnow details
HI @Wayworn
why would you delete your Rejected history and ask people to refer to my reply?
10-23-2024 01:49 PM
My Rejected Items
Testing for CS
2 weeks ago
Re: Has my number been compromised?
@computergeek541 wrote: @Wayworn wrote: Has someone taken over my number? Don’t know wh...
2 weeks ago
Re: Phone can't change sime 2fa esim
Yup - A physical sim is more flexible.
2 weeks ago
Re: my phone has LTE Reception with 5 bars but won...
LTE - 4G is the same.
2 weeks ago
Yup - A physical sim is more versatile -
2 weeks ago
2 weeks ago
Re: Subscription will not change
You need to contact customer support.
2 weeks ago
Re: 4G, 23 dollar/6 gig plan for new activations o...
NO worries- all is well, you will not lose this account.
2 weeks ago
Just find another provider and port out and be done with it.
2 weeks ago
The flexibility of switching plans up or down was exactly the reason I joined PM. But apparently sw...
2 weeks ago
- Re: Porting numbers
- Get Support
- Why not help all of us ?.
- 2 weeks ago
- Re: Submitting a ticket
- Get Support
- You got what you paid for.
- 2 weeks ago
- Re: US Roaming Talk Not Working
- Get Support
- Texting is best -
- 2 weeks ago
- Re: Looking for the $19/plan
- Get Support
- If you want to keep your number but just don’t need all that data etc consider Freedom Mobile - I...
- 2 weeks ago
- Re: How to change plan- downgrade
- Get Support
- Check your account page again. Maybe PM has changed their change plan policy or maybe not and I was...
- 2 weeks ago
- Re: Data depletes very fast
- Get Support
- Carefully check your settings making certain that WIFI assist is toggled off.
- 2 weeks ago
- Re: Plans for Snowbirds or Subscribers (not US-b...
- Get Support
- Just suspend your account and mark your calendar reminder to re- activate on the 87 th day or so ,...
- 2 weeks ago
- Re: Rewards
- Get Support
- Maybe you don’t have any reward points.
- 2 weeks ago
- Re: Just joined. Issues with texts
- Get Support
- Try turning off RCS because perhaps PM doesn’t support it and that may be the problem. ———
- 2 weeks ago
- Re: How do I Lift the Freeze on my Account?
- Get Support
- On the login page it gives you that option.
- 2 weeks ago
HI @Wayworn
unmoderated items are a system issue, did you reach out to PM support?
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
and @Handy1 , sometimes it is not bad to quote the original post 🙂
04-17-2024 02:17 PM
Thank you! You are right, my posts were rejected, but why?
04-17-2024 01:18 PM
HI @AliceLeiLei
use the link I posted above
if still cannot see others, post a screenshots
or if you have posted more than that, it might be spam filtered, check this
https://productioncommunity.publicmobile.ca/t5/premod/moderationitemspage/tab/rejected
04-17-2024 01:16 PM
Thank you for the quick reply. But I did not see my other post. I can only see this one. It's strange.
04-17-2024 01:15 PM
HI @AliceLeiLei
click on your name or use this direct: https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/336383
then click between Posts and Replies and you will see them all
04-17-2024 01:14 PM
Click on your ID and you will see your posts and replies
