12-09-2024 03:16 PM
I have the Mexico USA Canada plan. I have tried everything to make local calls: 011 + 52 + number...no luck. I have tried 001, 01. Who has made a local call in Mexico using their Public Mobile phone? Can you please share exactly what to dial. I'm trying to call 314 333 3982 .
2 weeks ago
@KeizerK My understanding is that toll free numbers can be problematic when roaming. Do they have a "regular" phone number you could call instead?
2 weeks ago
Currently in Mexico. I had no issues calling home but when I try to call a 1-877 number it won’t work. Suggestions?
a month ago
Thanks for letting me know. Yes, PM should have instructions on how to call from Mexico to Canada and the USA.
12-09-2024 07:19 PM
I did make a call while in Mexico to a number in Mexico and I finaly succeeded once I added the "+" in front of the number on my iPhone: +011 52-(area code)-xxx-xxxx.
To call Canada, I had to enter the "+" again: +1-(area code)-xxx-xxxx.
Would be nice if https://www.publicmobile.ca/en/on/get-help/articles/mex-subscription would include information on "how to dial" Mexico, USA, Canada and other countries.
12-09-2024 04:10 PM
that's new, I thought when roaming you call like you would when you are in Canada
12-09-2024 03:59 PM
no that is not it. A few others have posted that you simply dial the area code and then the number with no exit or country code. 10 digit number only and it works!
12-09-2024 03:58 PM
Yes that is the trick!
12-09-2024 03:57 PM
Yes that is correct. I just tried it and it works!
12-09-2024 03:42 PM
@will13am I read that within Mexico you now just dial the ten digit number without prefixes, so I think you are right.
12-09-2024 03:31 PM
@colinmccartie , maybe try calling as if it is a local code without the exit code and country code.
12-09-2024 03:18 PM
not sure if it is a problem with VoLTE, not all phones are VoLTE compatible with PM. What phone do you have?
and yes, calling by 011-52-xxx-xxx-xxxx should be sufficient. YOu can also try +52 xxx xxx xxxx
