01-09-2025 12:43 PM
I just returned from Mexico. I had a problem calling numbers in Canada (Edmonton specifically). When I tried to call with 1-area code-number. I received a message saying the number could not be accessed. However texting was working fine. Once I had someone at the number I texted call me once from their end, after that I could call that number back no problem. Any thoughts?
01-13-2025 11:11 AM
You input the "+" sign first before the number, so +1-(area code)-xxx-xxxx
01-09-2025 03:25 PM
You're dialing something wrong then, or your phone has some settings to append something automatically. Look through the settings in your phone app. My Pixel has "Assisted Dialing' in the settings, which I would start by toggling off and/or on, depending on what it's current set at.
01-09-2025 01:00 PM
we are in Mexico right now and can dial Cdn numbers without using 001 or +52...or any other trick. It works here just like it would ta home.
01-09-2025 12:50 PM
you can try asking PM why was that
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
01-09-2025 12:48 PM
No it was several different numbers. After someone called me from their number, I could call back to that number no problem without using "001", just "1".
01-09-2025 12:45 PM
was it just one number with the problem? you don't just call with a 1, you need to call : 001 + area code + phone number
