01-08-2025
09:40 PM
01-08-2025
09:43 PM
computergeek541
I just switched to public mobile. For my network, It says P is SOS and T public mobile. What is the difference between Preferred and Travel? I tried resetting my network settings but that didn’t work. I can’t make calls unless I change them to T but I’m worried I won’t be getting calls.
01-08-2025 10:12 PM
Thanks I’ll try the link. Haven’t gotten anywhere with the chat.
01-08-2025 10:03 PM
click on the orange bubble on bottom right side of page to start process of Customer Support help. Give them your acct #, ph #, name on acct and PM pin #.
If you're unsuccessful using the chatbot, use this link instead...
01-08-2025 09:59 PM
Yes I did port over my number. The network reset didn’t work.
01-08-2025 09:46 PM
when you activated your new account with Public Mobile, did you opt to port your previous number in to your account ? You could try a network reset...but you'll have to remember passwords as they'll be erased until you redo them after reset.
