12-06-2024 01:09 PM
I changed my plan, but I didn't get a refund for the previously paid amount.
12-06-2024 01:18 PM
if you message Customer Support to request refund / credit...please come back and let us know if your request is granted or denied. We'd all like to know in case this comes up again in the future, as I'm sure it will.
12-06-2024 01:13 PM
@MJY if you selected "Change now" you will not get a refund as Public Mobile is prepaid. You're best to select "Change on renewal" if you have a lot of days left on the current subscription
12-06-2024 01:12 PM
hi @MJY
did you use Change now option? if so, that is how it would be like, PM will charge new plan and won't refund the unused days
but if it is only day one after renewal , and you changed plan after renewal, likely PM agent can do something.
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
12-06-2024 01:12 PM
and you won't either. You were given choice to Change Now OR Change on Renewal. If you selected Change Now...you pay now and lose balance of previpous plan with no refunds or pre-rating of the plan.
