09-03-2023 01:45 PM
09-03-2023 02:01 PM
hi @Toxin hard to tell, depends
ESIM is great that you can activate anytime, no need to worry about getting a physical sim from stores or online. Also, if travel a lot, you can install multiple and change quickly on tje fly. But drawback is you cannot swap phone easily, many ask you to pay extra
09-03-2023 02:00 PM
I do hope iPhone15 have a SIM card slot!!!
09-03-2023 01:57 PM
I also prefer physical SIM card. Easy to transfer between phones. At the present time with Public mobile, if you need to transfer eSIM to a new phone, you will need to purchase another eSIM ($5) with your new phone.
Here is some more information:
https://www.publicmobile.ca/en/ab/get-help/articles/esim-faqs
09-03-2023 01:56 PM
You can't move an esim around to different devices (at least here anyway). You have to buy a new esim to move it to another device. You can move the card to a backup phone in case you have a problem with your daily driver.
09-03-2023 01:56 PM
Physical offers a little more flexibility. Say you get a new device you can just pop your SIM in and be on your way. With E-SIM on PM you’d have to purchase a new E-SIM for the new device.
09-03-2023 01:53 PM - edited 09-03-2023 01:54 PM
Why? With eSIM you don’t have to switch out cards when traveling but then again I’ve never tried eSIM.
09-03-2023 01:46 PM
Physical. All day.
