Number Transfer Failure
SimSimma
I chose to transfer my existing Bell phone number to Public Mobile during activation using an eSIM.
I received a text from Bell asking me to authorize the number transfer by replying YES, which I did. However, I'm concerned the transfer may not have completed properly because:
  • I can make outgoing calls.
  • I cannot receive incoming calls.
  • I cannot receive any SMS messages, including verification codes.
I have already deleted my Bell eSIM from my iPhone, as I believed the transfer had been completed. I now only have my Public Mobile eSIM installed.
I've already submitted a support ticket and am waiting for an agent to respond.
I'm particularly concerned because I have incoming calls I'm expecting today, and I currently have no way to receive them or redirect them to another number.
Is there anything else I should do? @CS_Agent
2 REPLIES 2
hi @SimSimma
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),Please use the same Community login you are using now.  (If you get stuck with the login or 2FA code, then use a different email address to create another Community account and submit the ticket with this new account):  https://expert-messaging.publicmobile.ca/guest/chat/
          Once you started the Chat, type "Submit Ticket", then "Connect Agent", and it will ask you to login to open ticket
          (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email" or "Send Voice Message")
Remember CS_agent will reply within 2 to 4 hours.  You will be notified via SMS/email or monitor here:
hairbag1
@SimSimma
make sure Public Mobile esim is set to primary. Then reboot your cell.
