03-07-2024 08:53 PM
How do I reset my activation so I can use the eSIM new account went to activate it said cannot activate contact pm tries to activate on different phone and said code used contact pm
03-08-2024 09:11 AM
I launched a ticket and I thnak you so much
03-07-2024 08:59 PM
changing the phone number won't help if it is an esim problem. I suggest to first ask PM support agent to check
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-07-2024 08:57 PM
Going to try this now I should of just picked a new number not transfer but my phone keeps saying sos hence I tried a new phone I will try the steps first then if not how do I get the activation to start on the phone that works
yes I got the welcome and tried the QR code but no success
03-07-2024 08:54 PM
esim can only be installed and activated once. You can try the following steps first and open ticket with PM support if nothing works
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, Please open ticket with PM support:
