Gratina kyocera kyf39 not making calls
Gdoe
Got the sim working, got the apn settings correct and it even worked for a few days making calls amd sending texts then it just stopped working. It will flash the phone number for a bit then disconnect the call before it rings. It can still send and receive texts, no amount of resetting, or taking the sim out and putting it in again, or airplane mode worked.
2 REPLIES 2
Chalupa_Batman
Just to confirm, your bill is paid up? Just know that phone isn't on the white list so they may not support you with help.
There have been issues over the last few days of folks saying their bill is paid up and their phone just stopped for no reason. You can reach out to a CS Agent to find out why.
You can submit  ticket by direct message:
A Customer Service Agent will reply to your community inbox here:
HALIMACS
Is this a new to you phone, @Gdoe ?
Purchased online?
Check your device on Device checker to make sure not blacklisted.
