Call Records
Carling1234_
Hello, I'm trying to collect past call records made with my number is there anyway I'm able to do that?
2 REPLIES 2
Carling1234_
Thank you!
@Carling1234_
Yes, just login to your account and go to Subscription tab>Usage Breakdown>View Usage History. Use the drop-down menu and click the 7 to 90 day history and on incoming or outgoing calls or both.
If you need further back history then you need to contact a CS_Agent.
