09-12-2023 04:34 PM
09-12-2023 04:48 PM
Thanks it is working now.
09-12-2023 04:48 PM
Thanks very much.
09-12-2023 04:39 PM
Did you select it as the active sim and then restart? (maybe airplane mode would work too)
09-12-2023 04:39 PM
@MKB Have you rebooted the phone or reset network settings , see if that helps if no luck use this direct link to support
send a private message To CS_Agents click
VVVVV Link below VVVVV
