06-05-2024
10:23 AM
06-09-2024
10:52 AM
Dunkman
I ported my number to Public Mobile but the eSIM doesn't appear to be working. Under "Cellular" it says "Add eSIM", then "Use QR Code". Also under my Primary number there is no "Network Selection". It's on "Automatic" but it's blank. I have data but can't call or text.
My account shows I have an eSIM (number displayed), purchased when I subscripted to PM. Since this one isn't working, should I just purchase another eSIM ($5)? If I do, how is the new eSIM linked to my current phone number? Will it still try to link to the first eSIM that isn't working?
I need an eSIM that links to my current number.
06-13-2024 11:09 AM
This worked. They reimbursed
06-05-2024 10:49 AM
hi @JArnold
supposed to be free. You can ask support agent for money back 🙂
06-05-2024 10:44 AM
It worked when I purchased a new eSIM for $5.60. I kept my old cell # and I was able to call and text again. After I purchased (and installed the eSIM), I had to turn my phone off and on again but at least I have it back. I'm going to ask PM for a reimbursement for having to purchase a new eSIM
06-05-2024 10:27 AM
THanks. Will it automatically link to my current phone number? Is the old eSIM disabled or not selected or.....?
06-05-2024 10:25 AM
HI @JArnold
yes, you can get a new , replacement one for free
just use the app, go to Account page and click Purchase sim card and follow the steps
