eSIM Activation
mason11
I’ve just purchased a PM plan with eSIM. I can log in to the app, where it prompts me to activate my eSIM. But here, after selecting a phone number, I get an error message. Why can’t I activate my eSIM? Thanks for any help!
2 REPLIES 2
hi @mason11
what phone do you have? did you allow the app to install the esim on your phone?
check Settings->Cellular or Sim Manager and see if the Public Mobile esim is there, enable it and try Reset All Networks
if not there, check if you received a Welcome email from Public Mobile.  If there is one, there should be an esim QR code and you can scan and install manually.
if not, then ask PM support agent for assistance.  You can submit  ticket by direct message:
slusagm
with error at that step, you will need PM to help to resolve the issue.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
