08-01-2026 02:15 PM
I purchased esim through the app. Install failed 3 times, I tried the qr code that I found by logging into my account on browser. Message says esim is not activated. Help! Side not I can't find any email from PM with the qr code (checked spam etc.)
08-01-2026 02:39 PM
if you used the app to subscribe, the PM eSIM is probably there installed already
First, remove the old carrier sim card, or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
Next, go to Sim Manager or Settings->Cellular and check if PM sim is showing there. Make sure the Public Mobile sim is enabled , or Turn on this line option is toggled on. Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work or let us know of if any the following does not work: inbound and outbound calls, inbound and outbound text, mobile data.
if the sim not connecting, ask PM support agent to help. You can submit ticket by direct message:
08-01-2026 02:22 PM
wrong place. Can't delete post.
