4 weeks ago
4 weeks ago
@Hardeep24 since it is a new activation, make sure you removed the old provider sim card (or disable the old provider eSIM)
Make sure that PM sim is enabled.
On Android: Check your Sim Card Manager and see if a Public Mobile eSim is there. If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there. If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
Then reboot the phone and click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
If it still does not work, you will need to have PM support to further assist.
PM support for further assistance. Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account. Select Start a Chat to begin:
https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/SMS alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
** If you cannot receive 2FA code via SMS and unable to open ticket, please use another email to setup a new Community account and DO NOT link a phone number to it. You can then create an Expert Messaging ticket using that new account.
4 weeks ago
@Hardeep24 Please provide more information on what you are having issue with. Are you getting any signal on your phone? How's your account status?
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
