2 hours ago
I'm currently on the $40 15GB 4G unlimited Canada plan. It seems a good choice to change to the "same" plan for $30. My question is: Do I loose my rewards points or my US minutes add-on ?
2 hours ago
@Gregory281, You should be safe to switch plans and not lose the add-ons you have already purchased and you will definitely not lose any rewards (referral points, anniversary etc)
2 hours ago
NO, you do not lose your points nor any add-ons you have nor any holiday bonuses you have on your account.
