01-13-2023 12:14 PM
Does anybody know why the usage on my iPhone shows hundreds of mbs being downloaded between midigh
Add-Ons
01-13-2023 12:20 PM
Thanks Much Appreciated
01-13-2023 12:18 PM
I don't think the stats are real time so when you see data usage it's usually just for the previous day's data usage.
01-13-2023 12:18 PM - edited 01-13-2023 12:18 PM
@tincase the data entry you see in usage history at midnight does not mean you were using that much data at that time
PM does not update the data usage constantly. Instead, PM ONLY put two data entries per day, around every 12 hours. So, the entry you see on midnight is the total usage for the last 12 hours, or the usage between that timestamp and the previous one
So, no worry
