07-25-2025 12:08 PM
I ported my Phone number last night, and im still in sos mode only.
07-25-2025 12:10 PM
Try Reboot your phone and reset network settings. If you have a physical sim, you can try on another phone
Last, you can ask PM to check the account setup. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
07-25-2025 12:10 PM
hi @Philipamar
it is not a problem with the porting but account not properly setup. PM support agent can help. you can submit ticket by direct message:
