RCS Not working
dcajic
I just switched lately and since switching I cannot enable RCS. I have an issue that it says RCS chats have been disabled by your carrier. I have a pixel 7 and I had it working before. I have tried enabling and disabling, restarting my phone. Data works and I even made new APN settings but nothing has changed. I have also tried clearing my data from the app but nothing seems to work. I am worried that something went wrong with the transfer. Also is wifi calling supported? I get a Telus not available page when I try to enable.
Thanks
1 REPLY 1
@dcajic try uninstall Google Message first (it will uninstall all the updates and go back to the base version). Reboot phone and reinstall/update Google Message and re-register RCS and it should work
