3 hours ago
Recently, my wife's phone indicated that she had run out of mobile data and was cut off. Previously, I believe her service would slow down rather than be turned off. Is this new behaviour? Is there a way to change it back?
Thanks.
3 hours ago
how much data per month she has ? if not a lot , better to toggle off mobile data if not needed
3 hours ago
it likely some app using data on the background. Are you using iPhone or Android? check the usage and try to find out which apps using most the data
