4 hours ago - last edited 3 hours ago by computergeek541
2 hours ago
hi @Tab999 international text is about receiving from any countries when you are in Canada, but it does not mean you can receive text overseas
If you want to receive 2FA, you need to use email or app when you travel. So, make sure you check with your banks to see what other 2FA options you have
2 hours ago
But even the $19 1GB 4G plan is only for new activations
2 hours ago - last edited 2 hours ago
The lowest plan is $19 now with 1gb of data and on 4G. The problem is that you probably can’t go back to your old plan after switching plans. Best to check your account after an agent helps you login to your account then go to the Subscription tab>Manage Subscription>Change Subscription and it will list all the plans you are eligible for. Your old plan is probably not listed.
4 hours ago
@Tab999 No sorry PM only has roaming in the US and the $15 plan is no longer available
