compatible phones for public mobile
Timbiga
How do I know if an Iphone 12 mini will work on the pm network?
JL9
While I am not an apple guy, my cousin has an iphone 12 mini with PM and he swears by it, so can't go wrong. (Samsung for Life though!!)
Timbiga
Thanks for the replies.
@Timbiga   Yes, iPhone will work on Public Mobile without problem.  And especially if what you got is a Canadian model, then it will work for sure
FYI, these are the frequencies to check for compatibility, and iPhone 12 has all the required one:
BCW
Yes your iphone 12 mini will work very well with Public Mobile.
Morning @Timbiga
Yes, iPhone 12 mini will work on PM without problem.  Basically all recent iPhones will work on PM network without problem
