compatibility
MGL
will this phone work on Public Mobile?
Samsung Galaxy A12 SM-A125F Dual-SIM 128GB ROM + 4GB RAM Factory Unlocked 4G/LTE Smartphone (Black) - International Version?
13 REPLIES 13
@mcfaddenclan   It  has been  broken for couple months already.
Which phone you are checking?  we can help
mcfaddenclan
The phone compatibility link is not working
@MGL wrote:
Does the Samsung Galaxy A32 5G have all the necessary band widths. Also when will Public Mobile go to 5G?
Public Mobile will not be offering "5g" service any time in the near future.  Public Mobile doesn't even offer the fastest LTE speeds that are available to new customers, so I would unfortuantely say that "5g" is a very long ways away.
MGL
@MGL wrote:
Thank you for this information it is very helpful, will not purchase this phone.
@MGL
In the future if you like to purchase any device for public mobile phone compatibility
you have to put it a device brand for any phone to you can see all information,
following >>To find out if your cellular phone is compatible with our network, click Here link
you can visit Here link
visit Here link to you can see full information about your device.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Good Luck...
MGL
LeePublic
@MGL Just an update, the phone is currently out of stock on the Samsung website. It's because there is a world wide chip shortage, which means there might be more phones that are out of stock.
agree with @LeePublic .  Samsung A1x is a good entry level phone with good price
LeePublic
@MGL Would recommend buying straight from the Samsung Canada website. It's $209 CAD. It would be guaranteed to work with Public Mobile since it is optimized for the Canadian market.
@MGL
is will work with public mobile but my suggest you to buy it Canadian Version is better...
Triguy
Yes, it is compatible but it does not have 1900 band.
Dunkman
@MGL
It will work, but might not work well depending on location.
Here are the specs:
https://www.gsmarena.com/samsung_galaxy_a12-10604.php
3G bandsHSDPA 850 / 900 / 2100
4G bands1, 3, 5, 7, 8, 20, 28, 38, 40, 41
It is missing an important 3G band 1900.
3G = 850 (5), 1900 (2)
4G = 850 (5), 1900 (2), 700 (12/13/17/29), 1700/2100 (4), 2600 (7), 1700/2100 (66)
Samsung A12 International  would work, but I will avoid
The 3G bands, it only have 1 of the 2.  So, it might not work that well..  You might have dropped calls.
Even LTE bands, it has only 2 compatible bands
