3 weeks ago
I have just purchased a pre-owned refurbished certified Samsung Galaxy S23.
Is this phone compatible with the Public Mobile network?
Thanks.
3 weeks ago
Yes, from the Samsung S21 or newer are VoLTE compatible on PM.
3 weeks ago
yes, Samsung S23 is definitely compatible.
But you can also confirm it yourself using the IMEI checker here:
https://www.publicmobile.ca/get-help/articles/volte
