Locked out
Kas2
Can anyone help me i just put in a ticket but i don’t understand also have had no service for 5-6 hrs
@Kas2 - okay, so you had service up until 5-6 hours before posting that?
Self serve does seem to have been down for overnight, not sure if that was affecting your log in ability. You put in a ticket last night? Do you mind sharing what the CSA may provide?
@Kas2   You called 1-855-4PUBLIC and if it said it cannot find you number ?  If so,  then your account was somehow closed
there could be 2 reasons for that since you only  lost service for couple hours
1. Some had access to your My Account and ported your number away
2. You have requested a chargeback to a PM or Koodo charge on your credit card.  PM will immediately suspend/close your account in such situation.
I suggest you open ticket with PM Support to understand what happened
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
Kas2
It doesn’t register my phone number like at all i just i really dont understand and im freaking out i even reset my network settings
@Kas2   any chance you have a chargeback on your credit card for a PM or Koodo charge?
if you call 1-855-4PUBLIC, enter your phone number, what does it tell you after?  can it find your phone number?
