06-16-2022
11:00 PM
06-17-2022
12:33 AM
computergeek541
hii, i am unable to reactivate my sim even though i have enough balance in my account can anyone help me with this ?
06-17-2022 06:57 AM
@nrkrahul007 - manually add enough funds to cover the owing amount (or add more), then select the resume/reactivate option.
Are your services currently working?
If so, and your renewal is today you can ignore that Expired message on your self serve, if you have enough funds to cover your renewal or on autopay.
06-16-2022 11:13 PM
@nrkrahul007 if you have a $25 plan, you only have $20 as Available Fund earlier, of course adding $1 would not help
Again, how much you have in Available fund now?
pay the difference between $25 and your current Available fund and see if it works. use the option "Other (enter the desired payment amoiunt) " and manually enter that amount. (do not use Amount Due, that usually have problem)
06-16-2022 11:11 PM
25$ is my current plan and i have tried paying 1$ but it just added to my account balance
06-16-2022 11:10 PM
06-16-2022 11:08 PM
i have to pay 10$ for activation but my account has 20$.
06-16-2022 11:05 PM
@nrkrahul007 First confirm if you see Available Fund is same or more than your current Amount due
If that is the case, try to go back to Payment page, one time payment and use the option "Other (Enter the desired payment amount)" to make a $1 payment. Once paid, click Reactivate current plan is the button is around, then logoff and reboot your phone
Check to see if it works
(If you don not have Available Fund same as your Amount due, load enough fund using the method above , using the "Other .. " option and manually enter the amount)
