3 weeks ago
Hi, I subscribed to the Public Mobile $29 plan and recevied the physical SIM card. But I was unable to activate the SIM despite following through the steps indicated in the Public Mobile App. It prompted me to ask for support in the last step (step 6). The CS was unable to help me and directed me here to submit a private ticket. Please advise.
3 weeks ago
If you click on your phone settings, then "Cellular", check to see if you have 2 SIM's listed, primary and secondary.
Make sure the Public Mobile is the Primary and make the secondary your previous provider and turn it off. The issue could be your phone has 2 active SIM's and your primary was your old provider. Then you should see the cellular network bars show up. Let us know if that resolved it. If not send a private message through that link above, I've read others that got a new eSIM provided by an agent and that worked to fix (if there was a charge, they will credit it.)
3 weeks ago
@Jen2024 No worries use this link to message support
