check 5G speed
seeun
I'm using it at a speed of 5g, but it's too slow. There's a lot of data left at the moment, but it's still slow.
And when the other person calls, they say that they can't connect at once, and they need to make a second call to connect. Please check this part, too
@seeun   The speed can be variable but since you are also having problems with voice calls best to contact customer service, use this link and then watch your inbox for a agent's reply, either indicated at an envelope icon top right, or click/tap your avatar for a drop down with Messages
seeun
I have an iPhone 14 Plus. 5g is available.
Sansan
What type of phone do you have?
Yummy
- Can you try your PM SIM in another phone to see if you experience the same issues?
- Maybe your phone is not compatible with 5G?
