08-02-2021 08:59 AM - edited 01-06-2022 03:06 AM
Hello, I recently ran out of minutes on my plan for the first time in a year or two. I found this odd so I had a look back through my usage and there appears to be a 40 something minute long call that doesn't exist on my phone that I am being charged for. How is this possible and is there anything I can do about it?
08-03-2021 04:22 AM
Nice catch as this table also contains info thats official but not actually true.....
If you have the current in market $15 plan with 100 outgoing minutes the following does not use minutes......
The following does use minutes....
Perhaps an edit is needed for your post.
08-02-2021 10:17 AM
@Dunkman wrote:Just a reminder:
Talk
Talk minutes are counted whenever you make or receive calls on your phone. Talk time is calculated from the start of a call to when it is disconnected, and includes ring time and call routing. Total call time is always rounded up to the nearest minute. Please note that calls to voicemail and forwarding calls will use plan minutes.
Use Minutes
Doesn't Use Minutes
Making a call
Calling *611 (the IVR)
Answering a call (not with $15 plan)
Making or receiving calls from 911
Retrieving voicemail messages
Using calling apps when connected to Wifi
Using call forwarding
This is VERY useful table but it might be confusing for new customers particularly on $15 plan.
When they see 'Answering a call...' under 'Use minutes' some might panic not reading the rest (not with $15 plan). Using minutes Answering a call does not matter as nobody is charged to receive calls (unless I am wrong?).
For those with unlimited incoming/outgoing calls count of incoming calls is just a number they do not care.
I would suggest modifying 'Doesn't Use Minutes' to have 'Answering a call on any plan'.
08-02-2021 09:20 AM
Glad to hear that you figured things out. The talk minute tracker is fairly accurate. Unable to delete your post, but it is fine to keep in forum.
Just a reminder:
Talk
Use Minutes | Doesn't Use Minutes |
Making a call | Calling *611 (the IVR) |
Answering a call (not with $15 plan) | Making or receiving calls from 911 |
Retrieving voicemail messages | Using calling apps when connected to Wifi |
Using call forwarding |
You can also purchase the $5 Canada wide talk add on that offers 500 minutes. Unused minutes do roll over to next month. It is a very useful and reasonably priced add on for the limited talk plans.
08-02-2021 09:04 AM
Sorry, I just figured out the answer to my own question, but can't delete this post. My own oversight!
