04-28-2022 11:20 AM
On Monday I changed my son's plan as he ran out of data. My credit card was charged but his plan still shows the old plan and he still does not have any data. He needs data today as he is travelling in the city.
04-28-2022 11:03 PM
@SherylP - if you were trying to renew his current plan, you have the first step complete...adding funds to the account.
But, you cannot renew a same plan early. You will need to ask CSA to do this for your.
Contact Public Mobile Representatives customer support agents (CSA), by either two methods, found here:
Or, up or downgrade, if you want perform a renewal yourself...just note, the funds are not prorated. So you do not get anything back from your current cycle if you choose the Change Now option or get CSA to renew your plan early.
04-28-2022 11:58 AM
How exactly did you 'change' son's plan?
Did you do immediate change or schedule it at next renewal?
04-28-2022 11:35 AM
If you selected change now it should be working right away, especially if you were charged and you don't see it in available funds balance. If it is still not working a CSA may be able to sort it out for you as that doesn't add up
04-28-2022 11:27 AM - edited 04-28-2022 11:33 AM
When you selected your new plan, you were to choose either Change now or Change at my next renewal.
Perhaps you selected the latter ? edit...if cc was charged then you selected Change plan now
Alternative option is to get a data add-on. First load $$ in to Available Funds...then select data add-on you want. Restart phone and your old plan is fine but you have some extrra data.
04-28-2022 11:23 AM
Did you just top up the available funds? Go back and select the new plan again and choose change plan now.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
