05-12-2021 02:28 PM - edited 01-06-2022 02:41 AM
my plan says deactivated - im on auto pay and none of my cards will be accepted - this is horrible. I have purchased a voucher and my balance is zero. what is happening??
05-12-2021 02:41 PM
05-12-2021 02:40 PM
Using lost/stolen will force the system to take your payment and reactivate your service.
05-12-2021 02:38 PM
@jthomson wrote:Your service is currently suspended due to insufficient funds.Available Funds: $27.00Estimated amount due: $0.00The amount due is based on your current Rate Plan
@jthomson Sometimes waiting an hour and retrying to Reactivate should push the payment. Use incognito/privacy mode for the browser though.
Did you try the lost/stolen method as suggested yet?
05-12-2021 02:37 PM
@jthomson after you add the voucher, if you check Payment-> Transaction History, you should see a line showing it is applied.
05-12-2021 02:36 PM
05-12-2021 02:35 PM
Go to the plans page. Click lost/stolen. Suspend your service. Log out/in. Resume your service. Your account should say active. Log out and Reboot your phone.
05-12-2021 02:35 PM
Purchasing Vouchers Accept payment vouchers, which you can purchase at select locations. To find the location nearest you click here. Payment voucher PINs are 12-digit numeric codes located on the receipt. The location of the PIN varies depending on where you purchase your voucher; however, you will typically find it on the top or the bottom of your receipt. To top up using a voucher, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘One Time Payment’. In the form on the next page, select ‘Payment Voucher’ as your payment method and enter your voucher code below, then click ‘Submit’.
05-12-2021 02:34 PM
says plan expired - so i chose reactivate plan and it wont accept payment saying no balance
05-12-2021 02:34 PM
@jthomson wrote:i put the voucher through online and it says i have $27 but it will not renew--when i go to balance it says $0 so what do I do?? Im on autopay.... why did this happen?
@jthomson Try clicking the Reactivate option (top right of overview page) and then reboot the phone. You may need to try couple of times. Also make sure to clear your cache/cookies and use incognito/privacy mode on your browser.
05-12-2021 02:33 PM - edited 05-12-2021 02:34 PM
@jthomson : Do you see the big suspended box on the top? Or does the status now say Active? Maybe restart the phone.
Edit: can you post a screenshot of your overview page. Blank out personal info of course.
05-12-2021 02:33 PM
after the voucher it says to reactivate account so i pressed and its asking for payment so i enter my debit and it says no balance to pay--i have no clue what to do.....
05-12-2021 02:32 PM
05-12-2021 02:30 PM - edited 05-12-2021 02:31 PM
@jthomson : Did you try using the 611 service to redeem the voucher? Maybe restart the phone. When you dial 611 what do you get hear?
Edit: slow off the draw
05-12-2021 02:30 PM - edited 05-12-2021 02:30 PM
@jthomson yes, Autopay will fail sometime unfortunately.
You said you have a voucher, did you try adding your voucher online or by calling *611? Once you added your voucher, go back and check on Self-Serve to see if you see a button to Resume your account. Click on that. Then reboot your phone
