cancelling my account
Lmowrey
How to I completely remove my account, phone # & auto pay?
8 REPLIES 8
This is an example of a customer wanting to leave no records behind.
This is where using a prepaid MasterCard on your account would be beneficial.
HI @CountyDownIeUk   you are good.  I like you take care of your friend  👍
CountyDownIeUk
@Lmowrey
Would you want to let some one take it over??  That is if it is on the old rewards.
@Tsawwassen
Luddite
@Lmowrey  If you are hoping to expunge all traces of you and your account, that cannot be done. The best you can do has been described by the other posts.
Yummy
Log in to your account and remove autopay. After 90 days of no pay your account will be deleted, phone number lost.
Ask agent to remove credit card number form your account.
If you need your phone number, port it to other provider.
If you want to stop using your account immediately, report phone as lost/stolen and 90 days counter start ticking right away.
JL9
If you do go through with cancelling make sure you remove your card or get CSA to assist you with that to avoid any incorrect charges down the road.
JK8
@Lmowrey
Call 611 from your phone and remove autopay. After 90 days from the renewal date without a payment your account will be closed automatically.
darlicious
@Lmowrey
Do you want to keep your phone # or abandon it?
