05-02-2023 12:09 AM
new to this. Account was set up and looks good but phone does not work for voice or data It doesn't have a phone number showing on the screen as attached to the phone.
05-02-2023 01:23 AM
Have done that. Will wait for reply. Thanks so much to all of you for the help so far.
05-02-2023 01:06 AM
I have sent a message to the CS_Agent, so will see tomorrow what happens. Thanks so far for the help and it is appreciated.
05-02-2023 01:02 AM
Watch for a response back from a CSA in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar.
05-02-2023 12:58 AM
@sportsman1946 wrote:I am no sure what you mean by cs-Agent
It's not CS-Agent. It's CS_Agent. It's the username that customer support agents use. They are the customer service department.
05-02-2023 12:51 AM
05-02-2023 12:49 AM
It sounds like it could be a provisional/backend issue with your SIM so contact a CS_Agent and they will fix for you.
05-02-2023 12:46 AM
The old account was Telus. I put the old sim card in the phone and my phone number shows up and I can callout to my voice mail. I can't get into my telus account as it has been closed.
05-02-2023 12:40 AM
If you ported your old number over to PM, did you reply to the text with YES within the 90 minutes window with the old SIM in your phone?
Also your old account must be active to port over.
If you missed the text or replied out of the timeframe. You need to contact a CS_Agent to restart the porting process for you again.
Submit a Ticket on SIMon Chatbot below or private message them on envelope icon above.
Staff hours are 6:00am to 10:00pm EST so they are off now but contact them now and they will private message you back.
05-02-2023 12:20 AM - edited 05-02-2023 12:22 AM
following the steps to port in are very important for successful activation. Who was previous cell provider ?
Your old account must stay active until ported into PM. Leave your old sim in the phone so you can respond to port request response.
clipped from Help files..
Transferring an Existing Phone Number
Transfering or porting your phone number from another provider, allows you to keep your existing number. Before you do, here are some things you should know:
Mobile Phone Number Transfer Landline Phone Number Transfer
| Old service provider brand | First and last name of account holder |
| IMEI Number OR Previous Provider Account Number | Complete billing address |
| Alternate Contact Phone Number | Alternate Contact Phone Number |
05-02-2023 12:13 AM
yes as far as I know I did.
05-02-2023 12:11 AM
did you port your old number in during the Activation process ?
