can not receive pictures text messages
KerryHu7619
Hi There,
I can not receive pictures text messages. May I know why? Thank you
12 REPLIES 12
HI @KerryHu7619
actually, you need to update your APN.  Please update as follow:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
@KerryHu7619
You will need to contact a CS_Agent to investigate the issue.
Phil_Adelphus
@KerryHu7619   If still not working, check the APN settings which should be as on this linked page
https://www.publicmobile.ca/en/get-help/articles/set-up-data-on-an-android-phone
Chalupa_Batman
@KerryHu7619 wrote:
Hi There,
Hello @KerryHu7619
Since you said it was a Vivo X100 phone....   I'm more of an iPhone guy myself. However, I was able to help someone resolve this with their Android phone. Now, this particular phone isn't on Public Mobile's whitelist so it make not work properly. You can try this and see if it works. Go into your network settings, find the carrier area, you will probably have your phone set to Automatic. Turn off automatic and pick Public Mobile. Then reboot the phone and try again. See if that helps.
KerryHu7619
Yes. I reset it but still not working
@KerryHu7619
iphone or android?
iPhone: Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings
Android: ettings > System > (Advanced) > Reset options > Reset network settings.
Tap RESET SETTINGS.
@KerryHu7619
https://youtu.be/XAWCUrKNJYU?si=SpO12HpxdH_YfObm
Hope this helps. I only know how on iPhones and Samsung phones.
KerryHu7619
how to reset network setting? I can not received since day 1
KerryHu7619
My phone is vivo x100
@KerryHu7619
OK, next step is to reset the Network settings on your phone and reboot your phone.
KerryHu7619
Yes. It is enable
@KerryHu7619
Is the data on your phone enable? It needs data for MMS to work.
If you need help with the settings on your phone. Let us know the make and model of your phone.
