03-02-2023 09:59 PM - last edited on 03-02-2023 11:33 PM by computergeek541
can not make calls or receive and my account is active and fully paid! I went into account which is supposed to be on auto payment by credit card and it showed a $4.00 credit. I went into system and made my months payment to see if that would help but still can not receive or send phone calls. My text works fine.. any suggestions
03-02-2023 10:02 PM
hi @wbarnes you are not the only one. Many has reported voice call issue, most of them have problem for both incoming and outgoing
don't think you can do much to fix it other than submit a ticket with CS agent and let them fix it. Please open ticket
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
03-02-2023 10:00 PM
@wbarnes Lots of folks having issue with this , some have had success reporting this to support
Watch for reply top of page to the
Right ( envelope image )
03-02-2023 10:00 PM
There have been issue since yesterday for some people with both incoming and outgoing calls.
Try to change to 3G only and see if it connects to the network at all with such settings
If that does not help, I suggest you to open a ticket with PM support and let them aware you are one of those, too. Some customers got the ticket to support and got it resolved quickly
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
